Hello everyone
Santa Claus brought me a new VAIO widescreen.
I can not find a skin that will fit the 16:9 aspect ratio. I tried the resize software that I found on the downloads but I could not figure it out.
Does anybody have any skins that will fit?
Or knows how to use the resize software?
Feliz Ano Nuevo to all
geposted Fri 26 Dec 08 @ 10:48 pm
Can anybody help me with this?
geposted Mon 29 Dec 08 @ 10:18 am
Download skin resizer from the download section. Pick any skin you like and make sure it is unzipped. Load the skin into skin resizer and type in the new screen size you want - ex. 1920x1050 for a 1920x1080 screen size. Make sure that the vertical size of the new skin is less than the total vertical size available. This will allow the skin to "float" on the screen and still allow you access to other programs with messing up the external video display. Rename the new skin to "skin name 1920x1050" and run the program. Load the resized skin and your all done.
All the credit goes to the author of the skin resizing program. He did a great job!
geposted Mon 29 Dec 08 @ 1:09 pm
