Hi,
I created a playlist of about 100 tracks. Is there a way to calculate the BPM of these tracks or should I calculate the tracks of the complete library to get the job done ?
Thanks
Francis.
Thanks
Francis.
geposted Fri 26 Dec 08 @ 11:55 pm
Load the playlist . Mark all the songs- Right mouseclick-scan for BPM´s. but i think that you should calulate all your song on your computer , let the pc work when youre not out on a gig ,even if you have like 10 000 song it only take one night on a new computer.
geposted Sat 27 Dec 08 @ 5:20 am
that is good advice mon......
as long as you have your music in a main folder
analyze bpm at your main folder...it will go through all subfolders
if you have cue set on songs.. already it will not affect it at all
Chances are however only few of you bpms may change (see the below 80 bpm rule)
geposted Sat 27 Dec 08 @ 8:19 am
