im new with vdj software but im wondering how to make the program to sync the big squares of the songs after i set them as the down beats together, what happens is that i set the downbeat just by clicking the bpm button for each track, and then when i hit sync thinking the program will sync big squares with big squares and small ones with small ones, it doesnt, it does sync the song but not following the down beat i've set, which i believe is the big square?? what do i do to fix this??
thank you
thank you
geposted Sat 27 Dec 08 @ 9:38 am
hit the play button wnen trhe big squares a almost aligned the hip the sync button
geposted Sat 27 Dec 08 @ 2:01 pm
but why is it that when i use the B shortcut for syncing it doesnt care about big or small squares??
geposted Sun 28 Dec 08 @ 11:12 am
there are two problems that could cause this
1. your bpms of the two songs are not correct - (
1. if your bpms are correct then your CGBs are not aligned correctly
large squares must be under the down beat.... every four beats.. large squares should be consistent
Syncing will not be correct it if it isn't aligned correctly
In version 5.2.1 nearly if all bpms are read correctly (of course some may read for 140 instead of 70) - check on how to detect bpm <80
Set shortcuts for on the fly correction of malaligned CGBS
Assuming that your bpms are correct you may need to nudge the large CGBS under the downbeats
what I do is create a shortcut that i can use to nudge the cgbs in place one button that left nudges.. and the other for right
geposted Sun 28 Dec 08 @ 11:27 am
hey thanx im gonna give it a try and ill get back with u
geposted Mon 29 Dec 08 @ 10:35 pm
I hope this solve your issues mon... it should
geposted Tue 30 Dec 08 @ 4:19 am
