I tried to register my nuvj console so I can try and see if it would be able to control the trial version of VDJ.. I can't seem to register it..
Do I need to purchase the software first, register it, then try to see if my midi controller would work??
Thanks in advance..
Thanks in advance..
geposted Sat 27 Dec 08 @ 6:19 pm
You cannot register with your NuVJ software serial as its a different product.
Their is a peice of software which converts the output but it will only work with a fully purchased copy.
geposted Sat 27 Dec 08 @ 7:19 pm
thanks fopr the reply..
I just read the "need to read" section in general chat..
One question though before I do purchase the software, does the nuvj controller work with VDj/CUE???
geposted Sat 27 Dec 08 @ 8:54 pm
