hi!
I use VJ home edition + Numark dj|io. I cant figure out how to use the mic in. I've read a few other posts here and it looks like the software does not support the mic-in...is that true ? Still, I've found a mic-in-volume shortcut in VJ, so I though there must be a way to use it.
Secondly, windows XP mixer seems also not to support my soundcard very well. Basically I can just use the line-out 1. Do I have to change drivers ?
Thanks in advanced, happy holiday.
geposted Mon 29 Dec 08 @ 5:03 am
firstly i own a djio and never used the mic but maybe in sound set up try 4,1 sound card.also are you running vdj5.21.some cracked versions wont support all inputs.become a vdj pro user for all benefits its well worth it mate
geposted Mon 29 Dec 08 @ 6:32 am
I run the home edition, legally purchased one week ago ! The pro is just too expensive for me a the moment.
I've tried the 4.1 setup but it does not work either.
geposted Mon 29 Dec 08 @ 7:19 am
The DJio mic is a physical passthrough to output two only.
It is intended that it is a very low latency playback device.
If you want a mic interface perhaps an Alesis I02 or Usb mic cable would help you.
geposted Wed 31 Dec 08 @ 5:48 am
Actually the mic through is sent to Output 1.
I don't really need a mic, but since I have it, I would like to try it.
So is it supposed to work with Virtual Dj or not ?
If not, how can I make sure my soundcard is not damaged or whatever?
geposted Wed 31 Dec 08 @ 11:52 am
It passes out to output one into your mixer its not intended for use with VDJ.
It allows you to talk over the music.
geposted Wed 31 Dec 08 @ 1:15 pm
OK! Now everything's clear, thanks.
geposted Thu 01 Jan 09 @ 10:13 am
