I have some mixes that are 15 to 25 minutes long when I use vdj to play these it takes a while to load. It never loads the entire mix it will load it as its playing it.
Do I need to do something different with longer mixes?
geposted Mon 29 Dec 08 @ 10:20 am
check your settings --> performance-> in the lower right corner is sth like max.trackload that can be set, for example 10 min, 30 min or max load. i think you should try max load. I am describing from memory cause i dont own vdj, but it is there somewhere. hope i could help. peace
geposted Mon 29 Dec 08 @ 10:37 am
that is correct, sir.
geposted Mon 29 Dec 08 @ 12:29 pm
i have the same issue.......long mixes load fine when i first start vrdj, but after long use (couple hrs or so) longer mixes don't load. furstrating for piss breaks later in the night
geposted Mon 29 Dec 08 @ 2:26 pm
What is your system specification and sound card?
geposted Wed 31 Dec 08 @ 7:22 am
