Is it possible to scratch with Virtual DJ? I mean, going from stutter cue to scratch, stutter cue -> scratch -> stutter cue -> scratch, and so on.
To simplify all this, my question is: Can you make Virtual DJ return to the cue point by itself, right after you release the platter after a scratch?
Is it possible to create a short cut that can do that?
geposted Wed 31 Dec 08 @ 3:34 am
If you are using timecode or a controller that you can scratch from ... you are in control of the tracks position. The software can not know what your intentions are just because you stop moving the platter.
geposted Wed 31 Dec 08 @ 7:06 am
Not true, it could be an implemented feature, I've brought up the same suggestion awhile back. The Numark CDX had a feature called "scratch + cue". You could do a scratch, release the vinyl, and when you did another scratch the song would automatically jump back to the cue point so you could scratch the same sound again. American Audio's "Velocity" CD player had the same feature but it was called "Beat Juggle Mode". I wish VDJ would implement this feature. Yes, you could say it's "cheat juggling" but it makes for some pretty cool lightning fast doubles.
geposted Wed 31 Dec 08 @ 10:02 am
