SOLVED
geposted Wed 31 Dec 08 @ 3:30 pm
Pls don't spam the forum and register ur serial;)
geposted Wed 31 Dec 08 @ 4:17 pm
spam? I had an issue so i posted it, then i solved it so i removed it. Please explain how that is spamming? I dont have a license im using a trial, im not convinced its worth buying. If you let people try the plugin wizard with the trial then that might help. But for now im not convinced i can adapt it to benefit me in any way.
geposted Thu 01 Jan 09 @ 5:46 am
Hi, cos there not an issue reported here n u just put "solved"??? There nothing to be discussed then thus create unnecessary thread;)
There is no mac trial atm i afraid and if u do use a trial on bootcamp on mac then u might find a lot of solution on the pc platform.
Purchasing the pro version is a way to go n worth investing. Furthermore u will be entitled to download the goodies n have an update version that is free till now. I do hope u will join us soon;)
geposted Thu 01 Jan 09 @ 10:28 am
I removed the post so it would get ignored you can delete this topic
geposted Thu 01 Jan 09 @ 12:24 pm
I will not delete the thread but hence at ur request i will lock it;)
geposted Thu 01 Jan 09 @ 12:47 pm
