I am using VDJ 5, mac version with a hecules RMX console,
Since upgrading from the vdjc version which came with de console I have a few bugs
- in the sound setup, whenever choosing the rmx as soundcard, this gives an error. I now select the 4ch soundcard. In the dropdown that appears I then choose the mx console as soundcard. This works, but I don't think it is the right way.
- Whenever I make a loop in VDJ Pro with either the loop keys on the console or with computer keyboard/mouse, the loop is nit beatlocked. Which meens al loops are slightly to long o short. This was not the case in the 'free' vdjc version
- When I used pitchbend in the vdjc version, it only pitchbended for one click making it easy to correct in small steps. In the po version, pitchbend stays on untill I tap the button again. This makes it harder to correct.
Are these bugs or can I change these things anywhere in the program?
geposted Fri 02 Jan 09 @ 6:40 am
Hi pls register ur pro n LE serial in your profile and grab the recent V5.2.1. Thanks:)
geposted Fri 02 Jan 09 @ 7:55 am
