I use the Echo Indigo DJ sound card and I know it uses a dummy input but what I am wondering (if possible), I want to use the onboard INPUT (Mic) jack for a microphone, but i can't set this in Virtual DJ. It seems to be attempting to use the indigo's dummy input.
any ideas?
any ideas?
geposted Fri 02 Jan 09 @ 4:31 pm
I can help you.
Do you want to use one of Echo Indigo jacks for Microphone?
geposted Sat 03 Jan 09 @ 5:54 am
It is the Indigo DJ not the regural one with inputs, I dont think it is possible. but if you have a suggestions let me know please :P
Thanks
Thanks
geposted Mon 05 Jan 09 @ 6:46 am
For your sound card, you can't use jacks for input!
If you read spec of Echo Indigo DJ you will understand that both of two jacks are OUTPUT:
2 independent stereo 1/8" analog outputs
There is Echo Indigo IO which has one INPUT and one OUTPUT:
1 stereo 1/8" analog input
1 stereo 1/8" analog output
For further information, read it:
http://www.echoaudio.com/Products/CardBus/IndigoDJ/index.php
You are welcome.
You are welcome.
geposted Mon 05 Jan 09 @ 6:58 am
You can set the microphone settings by this pannel of your S.O:
Pay attention that you need to check that your microphone is enabled by clicking on VOLUME button!
geposted Mon 05 Jan 09 @ 8:52 am
yea I know i have only outputs that's why i was wondering if it was possible. as for the mic it has to be setup in vdj i think.
geposted Mon 05 Jan 09 @ 1:45 pm
I am sure Echo Indigo DJ doesn't support input signals.
You have to connect your microphone on another sound card; if you don't use esternal mixer, not to forget to set "mic_volume" on your skin or on your MIDI device.
If you want to record microphone signal as well, you need to set it in this pannel:
geposted Mon 05 Jan 09 @ 2:08 pm
yes unforentaly i dont use an external mixer so like i figured this will not work :(
it was more of a let's see if I can then a I need to lol.
Thanks for the help though
geposted Tue 06 Jan 09 @ 6:53 am
You are welcome!
geposted Tue 06 Jan 09 @ 7:06 am
