hello i just bought this and i would like to no what do i need in order to hook it up to vdj.. i no tcc witch i can down load off the web site but what us will i need is the maya 44 ok to work with this set up.. did i just answer my own ? or can i just use my mk2 mixer as a sound card
http://www.123dj.com/packages/cd/3500pack.html
thanks djmonte
thanks djmonte
geposted Fri 02 Jan 09 @ 9:34 pm
the mk2 is a total control and a sound card ,and yes you can use it as a soud card . l hope this help you can ask and l'll try to help you
geposted Fri 02 Jan 09 @ 11:14 pm
