all of my music is on a external hardrive
so,,,,
when i set cues in songs and reset vdj or switch off my laptop
the saved cues are gone on them songs ????
no idea y it iis happening?
shaun
so,,,,
shaun
geposted Mon 05 Jan 09 @ 5:50 pm
When you power off, are you plugging the EXT into a different USB port?
geposted Mon 05 Jan 09 @ 7:31 pm
nope i dont, leave it in the same one
geposted Tue 06 Jan 09 @ 6:23 am
What version of VDJ are you using?
And do you shut down VDJ, before you disconnect your external drive?
geposted Tue 06 Jan 09 @ 9:42 am
the one that comes with dmc2 controller (cue)
yes i close vdj down then switch it off, load it back up and they have all gone again???
geposted Tue 06 Jan 09 @ 2:08 pm
Dont switch off the HD while Windows is still running. Shut down Windows first, then the drive
geposted Tue 06 Jan 09 @ 4:19 pm
