Get a print out of the songs that are in your library? What I am trying to say is, I have a specific folder for a specific genere of music. Such as House, Rap, Hip-Hop, etc. Is there anyway I can click on the folder and get a print out of the songs in that folder with the song key (E flat, E Minor) and the value (8a, 7a).
Syberman
Syberman
geposted Tue 06 Jan 09 @ 12:23 pm
VDJ doesnt have that feature yet, but its something I'd like to see..
Until then, you can use 3rd party such as Print Directory http://www.ashisoft.com/pd.htm
It will print out IDtags from your music files...
But not VDJ bpms and keys unfortunately
geposted Tue 06 Jan 09 @ 12:40 pm
Thanks Norway, mabye you can convince the higher-up's at VDJ to make this available in the next update. Does anyone know any third-party software that can enable me to do what I want?
Syberman
Syberman
geposted Tue 06 Jan 09 @ 4:18 pm
No 3rd party reads vdjs own bpm and keys.. its written in the XML file...
But I'll try get Dev Team to look into it as a feature.
Or you can ask at the plugin forum, if anyone would like to make a small plugin/program to do it. Its very simple...
If I get some free time, I'll make a special webpage that can do what you want, but a plugin/program would be better, if you ask for it at plugin forum :)
Jerem K might do it, it would probably be pretty easy for him to do
geposted Tue 06 Jan 09 @ 4:24 pm
That would be great! Thanks Norway!
Syberman
Syberman
geposted Tue 06 Jan 09 @ 4:35 pm
