How many cpu's can download the vdj, i have 3 computers and i would like it on all...is it possible..
geposted Tue 06 Jan 09 @ 12:32 pm
U may have it 2 at all times per license.
See the EULA;)
1. PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
Hope to see u with us soon;)
See the EULA;)
geposted Tue 06 Jan 09 @ 12:40 pm
it will be the djc edition....So i can and cant put it on 3 computers,,so if i want to change computers will i have to remove it from one computer and how will the cd know tht it was removed..im confused... what will the bck up copy do for my records? and im crunk because it will be here tomoro and i want to get started loading my computers but dont want to put it on both laptops and it wont take it...or how do i remove from 1 computer to put on another.
geposted Tue 06 Jan 09 @ 1:37 pm
Just uninstalled n then reinstalled. Just remembered it only 2 at all time per license for all version;)
geposted Tue 06 Jan 09 @ 10:19 pm
