Hey all,
Just started using the new version, noticed a few changed, like the time code waves in time code config?
Anyways, when i press cue/stop on my cd decks the virtualdj keeps playin weird and slow? any advice?
Thanks..
Thanks..
geposted Wed 07 Jan 09 @ 11:42 am
What timecode egine are you using V4 or V5 (timecode config)
V4 being the old engine, V5 being the new one.
geposted Wed 07 Jan 09 @ 11:44 am
V5 i belive , the default in the new version..
geposted Wed 07 Jan 09 @ 11:48 am
Any Ideas??
geposted Wed 07 Jan 09 @ 12:33 pm
Well, try the old V4 engine, the same one that is in the older versions of VirtualDJ.
It's the one I still use with my TCV. I can't get on with the V5 engine.
Cool, Will try it.. Thanks,
Wonder what the difference is..
geposted Wed 07 Jan 09 @ 12:37 pm
Well, this is what the wiki states
Quote :
"VDJ Timecode v5" for VirtualDJ vinyls, optimized for scratch (the old engine "VDJ Timecode v4" optimized for needledrop is still available)
Also make sure clear sound unchecked and master tempo is disabled.
geposted Wed 07 Jan 09 @ 1:13 pm
I started out with the total controller and cue LE I didn\'t really care for the jog wheels so I purchased 2 dz1200\'s a numark M3 mixer and VV. I\'m running 32bit vista service pack1. Every time I try to config my timecoded CD I get 0% signal and both decks on my screen go crazy spinning super fast or stuttering back and forth. I\'ve checked and double checked my cables. Before I purchased VV I bought a MAYA 44 and got the same results. Can anyone help me out with this!!!!
geposted Sun 11 Jan 09 @ 3:45 pm
cerriex wrote :
Hey all,
In timecode settings move your silence slider all the way to the right.
geposted Sun 11 Jan 09 @ 10:00 pm
cerriex wrote :
Hey all,
Thank you .. I just got that problem tonight .. this fixed it.
geposted Wed 14 Jan 09 @ 11:28 pm
