I'm having a problem...i got the ion imx02 mixer with VDJ program when i installed it on my computer running xp it worked fine... but when i installed it on my laptop running vista it says controller not plugged in ( the controller is the mixer connected by usb to your computer ). technical support on here told me there were no problems with the VDJ program and that it was a problem with my imx02 mixer drivers that were not supported by vista.... ok..... then i downloaded the trial VDJ program from this site and would you believe it the mixer worked perfect on my laptop running vista, so the drivers for the imx02 are supported by vista... can anyone shed some light on this problem???
thanks
paul
thanks
paul
geposted Wed 07 Jan 09 @ 11:56 am
Hi,
Its the reverse the mixer is compatible with all operating systems as its the host operating system which provides support.
There are no drivers as it is plug and play.
The included Virtual DJ LE is an older version of the software included free with the mixer as a taster , it was not designed to work on Vista.
Essentially you are purchasing the mixer, mic and headphones at a great price.
The full version of Virtual DJ will as will any other DJ software support the unit on Vista.
Kind Regards
Simon Bangs
Numark / ION PCDJ specialist.
Kind Regards
Simon Bangs
geposted Wed 07 Jan 09 @ 3:25 pm
thanks for the reply ... that makes sense now as when i asked the support team in the support/help section they told me it was the controller at fault which is why i was confused.... can i upgrade the vdj software iv got now or would i have to buy the new version?
many thanks
paul
many thanks
paul
geposted Wed 07 Jan 09 @ 5:24 pm
many thanks
paul
many thanks
paul
You would need to purchase the full product or see an alternative.
Either from ION UK as CUE (boxed) (includes local rate phone support) or VDJ as Virtual DJ pro (download).
geposted Sun 11 Jan 09 @ 5:29 am
