I'm still searching for help with virtual vinyl drivers. I have not had much success with Maya 44 and found a discounted vv card, but no drivers. Would appreciate some help!
Thanks
Thanks
geposted Wed 07 Jan 09 @ 1:47 pm
Drivers are not needed for the VV soundcard.
geposted Wed 07 Jan 09 @ 2:16 pm
Was just about to say the same thing
geposted Wed 07 Jan 09 @ 2:17 pm
Hi Drivers are needed only for XP or Vista.
If you need a copy email me sbangs@numark.com
geposted Wed 07 Jan 09 @ 3:40 pm
I must have been under a misconception that I could use the card with Cue. So I really need to purchase VV software?
geposted Thu 08 Jan 09 @ 1:05 am
VV box is bundled with the CUE, CUE is Virtual Vinyl itself. It will be a double expense if you buy the VV box (w/ CUE) for you have the CUE already. Try the other solution by purchasing a more PRO type sound card like Audio8 or U46DJ or even the Final Scratch Open.
geposted Thu 08 Jan 09 @ 1:33 am
Thanks for the input.
geposted Thu 08 Jan 09 @ 1:36 pm
