Hi guys, i've tried to do this but can't seem to find a way.
I'd like the gain on VDJ to be set at +2 permanantly for any track I load.
Is there away of doing this without having to change every track manually and use the remember feature, as this would take me forever!
Gary
Gary
geposted Wed 07 Jan 09 @ 9:04 pm
I thought I had a way to do it but my method did not work. May I ask why you need it to do this. Doing this may/will cause distortion??
geposted Thu 08 Jan 09 @ 1:52 am
Set +2 for first track in set, then always match...
And rest of set will be at same level
geposted Thu 08 Jan 09 @ 3:42 am
Thanks Norway, as for why, i'm doing a gig in a bar which has a very quiet sound system and my maya44 has a very low output. Going up to +2 on the gain makes a huge difference to the vloume output in this bar and the distortion isn't that noticeable for most tracks, so its worth the trade of in this particular venue for vloume over sound quality.
Gary
Gary
geposted Thu 08 Jan 09 @ 5:05 am
I had a similar problem with my old hercules.
I found out that the soundcard control pannel had the volume level set to about 70%..
After turning them to max, all was ok :)
Not sure if same thing apply to the maya
geposted Thu 08 Jan 09 @ 6:22 am
I seem to be running at 100% volume in the Maya's control panel. I think the card just has a low output. Its always seemed a bit quite but in other venues i've had some headroom to boost it on the mixer, but this new place doesn't.
geposted Thu 08 Jan 09 @ 6:44 am
Norway, i thought the "always match" was no longer available on 5.2.1, hmm i will double check cause i like using this feature.
geposted Thu 08 Jan 09 @ 10:59 am
I had to put 1000w per channel into the maya so that i had enough head room, I used a Peavey GPS3400 amp. Isn't there another soundcard that has better output there must be by now? I used mine for 6 years and stopped using it 2 years ago that's 8 years there must be something better now that isn't to expensive.
geposted Thu 08 Jan 09 @ 1:11 pm
Yes, there is Charlie, but we're talking ££££££'s mate, and it's all depends on how much you want to spend. I've been looking at the M-audio Connectiv soundcard, (around the £150 mark) I heard one recently and it's output is quite loud :)
As for the Gain options we only have, Auto+Remember, Auto, Remember and Disable now.
geposted Thu 08 Jan 09 @ 1:19 pm
U46DJ has a lot louder output than the maya.
geposted Thu 08 Jan 09 @ 1:26 pm
So i can't do the always match thing anymore?
geposted Thu 08 Jan 09 @ 1:49 pm
Thanks Jimmy for clarifying the gain options.......
I use the conectiv with cdj's and the output is loud and clear.
geposted Thu 08 Jan 09 @ 3:28 pm
I paid £170 for my maya, that's just how much stuff like that was back then however nowadays you can get a really good one for that as you stated jimmy.
geposted Fri 09 Jan 09 @ 6:51 am
I've got a brand new RME RPM sitting here in its box, just can't afford the ExpressCard interface to connect it to the laptop at the moment. I'm hoping once I can it will improve my sound situation a lot!
Gary
Gary
geposted Fri 09 Jan 09 @ 8:54 am
