Hi Guys , i changed from pc to mac and i cannot find the software to make the mk2 dj controler work on my mac without spending 200 euro .
The new consoles with software included, for mac are going in the shop for 200 aswell . Do i really have to throw my good working old one away.
Does somebody has some advise on this?
Thanks ,
Perry
Thanks ,
Perry
geposted Thu 08 Jan 09 @ 10:02 am
the drivers should be here http://www.hercules.com
geposted Thu 08 Jan 09 @ 10:16 am
Thanks for your reply.
Thats correct i can download the drivers from there but than i still dont have the software for mac
geposted Thu 08 Jan 09 @ 10:25 am
Only the new series of the mk2 or mp3 provide the V4.3 DJC for mac.
If urs is the older series, u can have to upgrade to pro version to have the mac version which u can with a discount;)
geposted Thu 08 Jan 09 @ 10:27 am
It might be on your install CD that came with the console.
If not, write Hercules support, and give them the serial number on the console box, and ask if they can provide you with a mac dowload
Or as Spinna says, you might have to upgrade to VDJ pro here at our site (you can with a discount), and you'll have both mac and PC version, full pro version of it
Thanks again for the quick reply . So far it seems the only option to upgrade to pro as i have the older system and i have been looking for months without succes .
I am just am bothered with the fact i have to pay again just to make it work as before .
Cheers
Cheers
geposted Thu 08 Jan 09 @ 10:37 am
Yes, it is worth to upgrade straight to Pro version rather than have to buy another console (new series).
Hope to see u with us soon;)
geposted Thu 08 Jan 09 @ 10:45 am
