Forum: Old versions
Topic: American DJ VersaPort issues
Is it possible for the VersaPort sound card to work with the Timecoded CDs? I have Serato SL-1 in another system and it seams to work fine with the timecodes and VirtualDJ, except when it crashes. But with the VersaPort it is using an ASIO driver and it responds a for a little while and then it stops working altogether. In the timecode setup it reads 0% timecode quality. Is the VersaPort even compatible? I am running on a HP Laptop with 2gb of ram on Windows XP.
geposted Thu 08 Jan 09 @ 1:43 pm
Is your American Audio Versaport working prperly with virtual dj now.
I had the American Audio Versa port a while back and it worked great for me.
i bought a versaport and only one turntable works how do i make them both
i got the versaport and it works fine for me
and guy with one deck working, only one channel hasthe phono preamp, so if you turn off the physical one and turnonthe preamp in vdj it should work, mine works like a dream with virtualdj, although it takes a while to get the timecode settings right
I am running the Versaport with VDJ and 2 American Audio Radius 3000's. The Versaport seems to be crashing every time about an hour and a half into the music. After about that time I go to load another song and lose all sound completely, I think have to close VDJ and either unplug the Versaport and plug it back in or restart my whole pc. What a nightmare while doing an event! Help
Yo i need madd help..my VERSAPORT DRIVER ACTING DUMB ON INPUT 1 aftr like 5 min of play..I NEED HELP..PLZ..
[Link removed]
OR TEX ME [Phone number removed]
thnx!!
[Sorry, posting contact details is not permitted for unlicensed users.]
MEIN VERSAPORT GEHT NICHT MIT WIN7.
Sorry, this forum is for English language messages only. Please either post your message again in English or post in the appropriate language forum at the bottom of https://virtualdj.com/forums
I'm having a problem with my set up hopefully someone can help me! I have vdj and Numark TT1625 turntables with serato tcv's and I'm using a versaport asio driver, my problem is that the left deck on vdj will not go reverse when i slide the vinyl in reverse and the right deck is a little skippy as well I've tried to configure both sides to be identical but still is not working for me I'm not all that technically inclined so please bare with me!
hey guys!
i was using MAYA 44 in my club,but the sound it's not sound very welll.so i was planning to buy MIXVIBE U-MIX 44,Versaport .
please which one you guys think is more better tham MAYA 44? out of the two MIXVIBE U-MIX 44,Versaport?
My regard
