I bought a new laptop, i tried to install my virtual dj sofware and when i tried to open it it gives me a Protection Error 48. Anyone has a clue? The same software still work fine in my other laptop. Thanks
geposted Fri 09 Jan 09 @ 8:40 am
You will need to contact support.
From what I can see on a quick google, protection error 48 seems to originate from previously installed versions.
You might also want to consider registering your serial on this site to grab the latest updates - see if that helps :)
geposted Sat 10 Jan 09 @ 3:26 am
