if you buy serato TCV and use it with Virtual Dj, instead of Virtual DJ TCV. will it work?
geposted Fri 09 Jan 09 @ 10:13 am
Yes, Serato vinyl will work with the Pro version
You just have to choice the "noisemap" timecode engine (VirtualDJ Pro 5.1 and above) in the timecode config
geposted Fri 09 Jan 09 @ 10:29 am
wow, thanks jimmyb. do you think Serato TCV is better than Virtual DJ vinyl when it comes to sensitivity and performance during scratching?
geposted Fri 09 Jan 09 @ 11:01 am
Don't no mate, never used Serato, and I guess I'll never will.
VirtualDJ does everything I want it to do mate.
geposted Fri 09 Jan 09 @ 12:34 pm
Depends on needles and turntables.
Some say our is better, some say Serato ones are....
But the experience depends on your hardware...
geposted Fri 09 Jan 09 @ 12:48 pm
Correction it works but the timecode cue marks are jacked up sometimes. I personally wouldn't advise it. Seeing how I own both Virtual Vinyl and a ttm57
geposted Sun 11 Jan 09 @ 3:23 am
