Forum: Old versions
Topic: Hercules Live, Yes or No? - Page: 2
Yes, SYNC is the answer..
here is my post on the new features section asking for: Sync off option
Anyone who has used the hercules dj console will know very well that the main flaw is the "play" button/control.., so most of us now are useing the "sync" to replace "play"...
This is all very well, but some of us want to be able to simply press play (mix the manual way) and not to sync on beat (automatically)..
As far as I can understand, it would be posible to have an option in virtual dj that would either ENABLE or DISABLE the sync function, If the sync function was disabled then the button would simply act as play..
So now the sync button (because of vdj software) can act as either SYNC or just PLAY..,
do you understand? (I tryed to explain as simply as possible), I think this would be possible, what do you think?..
Bagpuss,
I think (haven't checked the mapper) its quite possible to remap the console, so that the sync button is actually just plain play...
try the hercules mapper...
i only use the joggs and soundcard of the hdc. and the eq.
the rest i don't use. it's not working right(or not at all).
Play is sticky ...
Cue is sticky too, try to shortly hold cue in order to play a part of song and then release
the cue button, sometimes the song continues to play for a short time even if button is not pressed.
Are there problems with any other buttons ?
When I dissassembled the HDJC keyboard the sync button is made from the two surrounding "o" shape contact planes and on the rubber button there is "o" shape layer to conenct these two.
The other buttons are just two neigbouring planes connected with the rubber...
Play and cue buttons have 2 contacts one in the upper part and one in the lower area.
I even cleaned the whole keyboard from the "fat" with alcohole.
Will try to replace the play and cue button with some micro-click externally and will see if it is
a mechanical problem in the keyboard or rather o software problem.
Did someone else find out something regarding this ?
Nice day to all
Lopez
btw. a nice feature could be to make an internal mapper in VDJ for Hercules, that could be much better than only to give an option to switch off the sync function.
Yes I would appreciate more options too, It would be good if you could limit the software EQ to 0, then If you cut the bass on the hercules and restore it, you wont risk going over 0,
This would fix the problem with EQ on the hercules, if you get what I mean.
This is a great thread guys.., I wanted to post here to keep the topic alive, to save others from repeating ourselves.
Bagpuss (hows your hercules?).
perhaps I'll get an blown out controller from dual cd deck and rewire it to the hercules :-)
or will save some money for the controller with display
