I own 2 cdj800 mkII decks and own the hercules rmx console and am wanting to connect the lot whilst using the great (thought i'd get that in ;-) haha) virtual DJ. Could someone tell me how to do this amazing thing.
:) Thankyou, in advance of course.
geposted Fri 09 Jan 09 @ 5:23 pm
You can, connect them to the RCA inputs 1&2, 3&4 on the back of the RMX.
But I think you need to have the Pro version to get the full benefits of the timecodes.
geposted Sat 10 Jan 09 @ 1:28 am
aw.
Ok then, i will have to look at purchasing the professional edition then :)
But. Before i do, can anyone now tell me what to do if i did get the professional edition and verify that i could do this.
geposted Sat 10 Jan 09 @ 4:34 am
When you get the Pro version.
One to input 1&2 and the other to input 3&4
Download the timecode file from this site, burn to CD and use with your CDJ's. Config VirtualDJ to run with timecodes and away you go.
geposted Sat 10 Jan 09 @ 4:40 am
There appears to be sound on the VDJ PRO programme (the sound waves) of my friends, but it still comes up with the message which can be viewed. The Sound is actually still coming out of the speakers, but in no way does that appear to be linked/assosiated with VDJ as the track played on the pioneer cdj800mk2 can't be EQ'd etc.
My friend has the latest hercules drivers (as he also has an RMX console), and is running VDJ 5.2 Pro. Sorry to be a hastle, but can anyone give me some feedback as I want to ensure I can do this without paying all the extra money for vdj, only to find out i cannot do it.
Again, many regards in advance for the feedback. :)
geposted Sun 11 Jan 09 @ 10:00 am
Sorry it doesn't appear to be showing on the forum. Please visit:
http://img186.imageshack.us/my.php?image=timecodeerrorcs0.jpg
and click on the picture to increase the size of a print screen i have done.
geposted Sun 11 Jan 09 @ 10:02 am
There you go
It looks like you have chosen the PCDJ timecode engine in the timecode config. If you are using VirtualDJ timecodes you must choice the VirtualDJ, V4 or V5 timecode engine.
geposted Sun 11 Jan 09 @ 10:07 am
Thankyou. I assumed that it would be PCDJ as i thought it was an abriviation, but regardless, with your help, i no longer have the message that tells me that i don't have a timecode (50% frustration over.. :P).
But now, the trouble is the timecode quality never goes above 0% on the correct signal (v5). Also, the song plays when virtual DJ is not even on..which suggests something obvious.
I really appreciate your feedback. Thankyou.
geposted Sun 11 Jan 09 @ 10:38 am
Have you tried the V4 engine, and what grade of timecode are you using, Pro?
Uncheck Invert stereo and Invert phase.
Could you possible do another screen shot of what your getting now.
geposted Sun 11 Jan 09 @ 10:43 am
I tried to use v4, but it did not have any response again referring to the "No time signal error."
I have burnt the disk, but just to be sure where do i put this and how does it lower the DB volume? Im using the pro one as it advised that if you are using a cdj800.
Thanks.
Thanks.
geposted Sun 11 Jan 09 @ 10:50 am
Yes that's right, the pro grade timecode as already been lowered -14db.
geposted Sun 11 Jan 09 @ 10:56 am
Sorry about the delay with that, it appears image shack servers decided to die..haha.
http://i43.tinypic.com/1zyzfog.jpg
Thats directly after i click Auto-Config
geposted Sun 11 Jan 09 @ 10:59 am
geposted Sun 11 Jan 09 @ 11:05 am
Yeah, i click auto-config and it does not achieve any signal strength. Perhaps this will help.
http://tinypic.com/view.php?pic=211v56w&s=5
That is my setup within the hercules taskbar.
geposted Sun 11 Jan 09 @ 11:13 am
Try moving the Silence and Gain sliders to about 25-30% from the left.
Put you Asio buffer on around the 900 mark (19m/s I think) on the hercules control panel
BTW you can upload your images directly to the site by pressing the camera box at the bottom of your post page :)
geposted Sun 11 Jan 09 @ 11:15 am
Sorry i could not find the photo button.
Again, no luck im afraid.
http://tinypic.com/view.php?pic=2hoek3o&s=5
The only point of confusion is where do i put the cd with the burnt timecode cd?
geposted Sun 11 Jan 09 @ 11:26 am
I don't get what you mean? Have you been using the CD?
Once the timecode is on the CD, you then use the CD as a normal CD and put it in the CDJ, then hit play on the CDJ. Once it's playing hit Auto config in the timecode config
geposted Sun 11 Jan 09 @ 11:39 am
Yeah i did that, and again still no luck. I am starting to run out of ideas, which leads me to think maybe i've gone wrong in the basic setup.
I play the audio through dual jack direct output of the hercules rmx console to a headphone jack in my speaker system. I have then connected rca cables 1-2 (audio out) from the cdj800mk2 to 1-2 (input) on the hercules rmx. I also have technics rpdh1200 headphones plugged in.
For this, im using the latest drivers just released from the hercules website and am using virtual dj pro 5.2.
Does this all sound right?
geposted Sun 11 Jan 09 @ 11:48 am
That sounds about right, basically CDJ connected to input 1&2.
My RMX is packed away, but if I'm right there are 2 little black switches on the back of the RMX, line/phono switches I think. When I connected my 1210 up to my RMX, when I didn't have my Maya. I had them switched to "line".
You could try that.
You could try that.
geposted Sun 11 Jan 09 @ 12:00 pm
Sorry about the late reply, decided to give it a while as it boiled over into over-annoyance!
Yeah. My switches are set to line, so can't really comprehend why it's not working. Blahh. I know a guy who does sound engineering @ uni. I'll ask him to pop around. When i find a solution, i'll let both you and anyone monitoring this thread know.
Thanks for all the replies!
geposted Tue 13 Jan 09 @ 6:35 am
