hi guys, i've just joined the forum so i'm new here. i've been using VDJ for about a year now. it's a real awesome program, so mad props to the creators.
i have a couple of questions about the software:
1. is there anyway to raise or lower both the gain levels at the same time gradually or instanly using shortcut keys? i've tried looking in the config section but had no luck.
2. is there anyway to play both decks at the same time?
geposted Fri 09 Jan 09 @ 7:43 pm
Can you hit two keys at the same time? Check the mixer section in keyboard shot cuts. Yes, you can play both players at the same time. What version are you using? What happens when press play on both players at the same time?
geposted Fri 09 Jan 09 @ 10:48 pm
used it for about a year ?
geposted Sat 10 Jan 09 @ 8:09 am
show props by buying a license :)
geposted Sat 10 Jan 09 @ 9:37 am
Yes
Also yes.
Both questions have the same solution :)
The answer is in my next post, but you will need to have purchased a copy of VDJ (any copy) and registered it on the site to be able to view it. A bit mean perhaps, but as you've been using it for a year I feel it's only fair ;)
geposted Sat 10 Jan 09 @ 12:57 pm
