I finally had a chance to play with my rmx controller.. But I have one problem.. The source input button is inop.. I tried to input the sound from my dvd player into the controller but it's a no go..I am using the provide software that the RMX came with at the moment..Could this be the problem?? Do I need to install pro to get it to work??
geposted Sat 10 Jan 09 @ 3:44 am
I also set the sound card to 4 output if that helps...
I need the source input to wo0rk so when I use my laptop to play the slideshows, I have the rmx to contol the volume..
Any help would be greatly appreciated..
thanks in advance..
thanks in advance..
geposted Tue 13 Jan 09 @ 2:03 am
Try to set the soundcard in VDJ to RMX. Then VDJ and the RMX is set to ASIO-mode. The source buttons should work then.
Greetings Tanzi
Greetings Tanzi
geposted Tue 13 Jan 09 @ 8:08 am
off the top of my head think these should be your settings (really should remember, but i'm tired, lol.) open vdj > config > sound set up....
inputs > none
output > headphones
soundcard(s) use rmx
eg > do not tick
master output chanell 1&2 h/phones chanell 3&4
inputs > none
output > headphones
eg > do not tick
geposted Tue 13 Jan 09 @ 2:55 pm
as far as i know from the hercules website you have to change your settings on your rmx console screen to inputs 3/4 instead of 1/2.not sure but i would like to use laptop 1/2 and also say ipod 3/4 is this possible
geposted Tue 13 Jan 09 @ 5:23 pm
Thanks for the replys everyone..
I'll give it a try tomorrow and I'll keep you updated..
geposted Wed 14 Jan 09 @ 2:22 am
Ok..I finally gave it a try..STILL A NO GO!!!
dj console rmx:
input 1-2: line in/phone
input 3-4:line in/phone
firmware v.1.1.29.4
sound setup in VDJ:
inputs: none
outputs: headphones
sound card: 4-out card
driver:hercules dj console rmx aggregate
output channels: master: chan 1&2/headphones cahn 3-4
I have my ipod connected to input 1-2 and still no sound with the source 1 button pressed..
all this run on a macbook with osx 10.5.5 4 g ram..
Faulty unit??? If I try to make the sound card as the rmx console, I have a "error in sound driver" message..
any help would be greatly appreciated..
I just want the output of my dvd player to be input into source 1 so I can have audio when I play the slideshow..
dj console rmx:
firmware v.1.1.29.4
sound setup in VDJ:
inputs: none
outputs: headphones
geposted Sun 01 Feb 09 @ 6:19 pm
Hi tech126,
It sounded that u have the pro mac version of VDJ. I would advised to register it at ur profile and get the recent version that is available;)
Regards;)
Regards;)
geposted Mon 02 Feb 09 @ 2:50 pm
Return to the configuration Tayla suggested previously regarding VDJ.
Next, go the the Rmx Control Panel, and make sure that for Input 1/2, LINE IN is selected, otherwise it obviously won't work.
geposted Tue 03 Feb 09 @ 11:25 am
I can't use rmx as a sound card or else I'd get a sound card error..And yes, I've made sure that the input 1/2 is selected..
Thanks everyone for your inputs..
geposted Tue 03 Feb 09 @ 11:39 pm
Strange.
If you go in the Rmx Control Panel ABOUT tab, what information do you have there ?
geposted Wed 04 Feb 09 @ 2:07 pm
