Hi all happy new years
Well in the next month I would like to purchase dj console or Hercules, mk2, rmx or something to mix my music with. I would love some feed back on what’s the best one
Or what is everyone is using thank you for your time tony a.k.a. bigtonyt
geposted Sun 11 Jan 09 @ 7:03 am
Alright Tony
If you are going with Hercules, go for the RMX, its the latest controller, the mk2 although it still does the job, it's old now. The RMX does the more professional. Both as you know a native controllers. Also worth looking at the Hercules Steel. Basically it's the RMX without the built in soundcard
If you have a look at Numark, they have a new controller out, called the Onmi, It's similar looking to the RMX but slightly smaller, and slightly cheaper, but stills looks good. The Onmi is not native to VirtualDJ yet (although I believe in the next update it will be) but there is a xml mapped file for it. The Onmi to has a built in soundcard.
geposted Sun 11 Jan 09 @ 7:32 am
have to agree with jimmy about the rmx.was a bit afraid to get it at first but after hercules updated their drivers i love it.does a great job for me anyway
geposted Sun 11 Jan 09 @ 7:39 am
if you have the chingy.. and can wait..
The NS7.. just about should do it
geposted Sun 11 Jan 09 @ 3:23 pm
i say the ns7 of course if you have the money. but my main bit of advise is wait the week end and see what NAMM has instore this year. Other than the NS7 I really dont think thier will be any major bombs dropped. but I am sure little things may pop up worth looking into
geposted Sun 11 Jan 09 @ 3:27 pm
Hy tony,
we have a short time ago a similar case.
Have a look, maybe it helps too. ;-)
https://virtualdj.com/forums/102384/General_Discussion/Is_there_a_controller_comparison_thread_.html
Bye
Haui
Bye
Haui
geposted Sun 11 Jan 09 @ 3:34 pm
Hey all thanks for all your help on my question. about buying my hardware I look and read some info on the two that I would like to buy can some one tell me if they have used this one before vci100 and I like the rmx I know the rmx work with vdj what about the vci100 thanks for all your help
geposted Sat 24 Jan 09 @ 7:43 am
