i want to use my dj console and all the effects with it . but if i go in sound cards they say only avaible in pro version ,
i have buyed the pro version , but there i cannot use my dj console and effects are not active , yes some , the best are not active
wat can i do ?
wat can i do ?
geposted Mon 12 Jan 09 @ 8:45 am
Hy juliokabas11,
do you have activate under remote control your controller?
Look at the images, if there is your controller activate with klick the left mouse button.
Which controller do you use?
Greetz
Greetz
geposted Mon 12 Jan 09 @ 8:56 am
Haui70 wrote :
Hy juliokabas11,
Greetz
Greetz
yes i have try it but not work , i use the dj control mp3
but in store on the box u cannot see if it pro or not .
they have another one bit more money i want to buy it . but how i know i can use my headphone mixer or soundcards ?
geposted Mon 12 Jan 09 @ 9:07 am
Is it possible you have the Limited Edition Software also aboard?
I knew a guy who had also problems with the mp3.
If you like, deinstall all vdj software products, but copy your effects (other thread) and other stuff you had in a save folder.
After deinstall, clean the regstry.
Then install only the pro version.
OK it's a hard cut, but if nobody else has a better idea test this.
If you have a secod soundcard you can use headphones and and play to your crowd simular.
You must them adjust in the soundcard folder.
The other Hercules MK2 has included a soundcard.
Let's see if anybody else know the problem.
If it's work well, hope we can help you also to find the righ adjust.
Good luck
Haui
Good luck
Haui
geposted Mon 12 Jan 09 @ 10:51 am
Stop, if you have a second PC oder Notebook, you can test it befor deinstall.
Bye
Bye
geposted Mon 12 Jan 09 @ 10:54 am
You have already asked SAME question before at the forum... please dont open several threads for same question
https://virtualdj.com/forums/102788/General_Discussion/effects.html
geposted Mon 12 Jan 09 @ 10:56 am
