is it possible to use the souncard in the Evo5 as a TIMECODE set up in conjunction with the Denon 5500?
geposted Mon 12 Jan 09 @ 4:02 pm
The Ecler Evo 5 works well for TC solutions - if you enable TS mode on a channel it will work as both input and output simultaneously, allowing you to still leave 2 channels free :)
geposted Mon 12 Jan 09 @ 5:03 pm
Thank you for that bit of info in regards to the EVO5... My next question is it possible for me to download the TC file and be able to use it from the DENON 5500 Hard drive?
geposted Mon 12 Jan 09 @ 5:18 pm
Of that I have no idea I'm afraid.
geposted Mon 12 Jan 09 @ 7:52 pm
I have evo5, but i use VV sound card for TC. Anyway, i believe it works like SBDJ said, but i never tried. Yes, you can play TC file from denon 5500 and denon 5500 CD.
geposted Tue 13 Jan 09 @ 4:30 am
Thank You Xeon 4 dat bit of info, I really appreciate it.. thank man...
geposted Tue 13 Jan 09 @ 6:25 am
Xenon I am having a bit of problem.. I was able to get the TimeCode up and running but I am hearing a beeping sound come through my speakers.. what am I doing wrong?
geposted Wed 14 Jan 09 @ 12:36 pm
Mute the outputs for those inputs, in your soundcard settings, so that the timecode signal does not get played out loud
geposted Wed 14 Jan 09 @ 12:39 pm
yup, mute them ;)
geposted Wed 14 Jan 09 @ 12:45 pm
i don't know how to do that.. what i have been doing is turning down the input channel of the Time Code... but I am unable to monitor with headphones between channel 3&4 (these are the output channel of the software) remember I am using the EVO% mixer... any suggestions guys..
geposted Wed 14 Jan 09 @ 5:59 pm
I dont have that mixer (yet) myself;)
But there should be a control pannel for the Evo soundcard settings, where you can mute the inputs at the output, preventing sound to be channeled to the master out.
geposted Wed 14 Jan 09 @ 6:01 pm
Thank you Norway.. What do u suggest I do about being able to monitor between channel 3&4 when they are both in the same channel?
geposted Wed 14 Jan 09 @ 6:13 pm
monitor..
Ok sounds like your souncard setting for Evo has a monitor setting.
You should mute monitoring for the inputs...
geposted Wed 14 Jan 09 @ 6:15 pm
ok.. I am gonna check on it and get back at U Norway
geposted Wed 14 Jan 09 @ 6:23 pm
k.. hope you figure it out ;)
If not Xeon will.. he has the same mixer I think...
geposted Wed 14 Jan 09 @ 6:42 pm
Did you enable TS mode on the two channels in the MIDI mixer setup screen?
geposted Wed 14 Jan 09 @ 10:16 pm
Yes, i have EVO5, but i don't use internal sound card for TC. I have VV box as sound card. Well.. will try to see how to fix it, but don't have time at the moment.
It's everything in settings, just play with them :) btw, there is software for mixer available (you got it on CD too), check it!
geposted Thu 15 Jan 09 @ 3:41 am
I can write up a guide later if you want, I've got a TCV overlay already set up and working on mine :)
geposted Thu 15 Jan 09 @ 6:25 am
SBDJ.. that would be perfect man.. I would really appreciate that.. if its no bother to you at all, that would be great... I'll be looking out for it.. thanks again man...
geposted Thu 15 Jan 09 @ 6:30 am
I will also check on the CD today to see whats there..
geposted Thu 15 Jan 09 @ 6:32 am
