I thought I would try here before posting in technical section, seeing as your all bright sparks etc etc...
I get a high pitch whine from my tcv, and its starting to get louder, not noticable at high volume but by god its irritating.
I have changed stylus etc, it just dont go!!!
oh and yes the tt's are earthed.
Is it fixable or shall I just end it all with a sharpened potatoe?
geposted Mon 12 Jan 09 @ 5:06 pm
you mean from the physical vinyl, and needle... or through your speakers?
The needle wine, is a bit annoying yes, but wont get heard on on the speaker system
geposted Mon 12 Jan 09 @ 5:09 pm
its coming thru my speakers!!!
Its trying to kill meeeeeeeeeeeeeeeeeeeeee
ok I am exagerating, but at low volume its like the noise you hear when your being brainwashed (dont ask how I know)
geposted Mon 12 Jan 09 @ 5:12 pm
You do get a slight wine from the stylus/cart picking the timecode up thats normal, well I hope it is, lol
but though your speakers, no I don't think so. Could it be possibly be a earth fault from your TT's.
geposted Mon 12 Jan 09 @ 5:22 pm
checked...re-checked, used diff cables.....
gonna see if I can make a nice hard dance tune out of it
geposted Mon 12 Jan 09 @ 5:27 pm
what sound card are you using. maya44 have an option to mute the output without it affecting virtual dj
I am using maya44 should i give it a try?
how will i still get sound if i mute the output?
geposted Mon 12 Jan 09 @ 5:29 pm
I have a Maya too, and I'm also wondering how this works!!
geposted Mon 12 Jan 09 @ 5:40 pm
it was from a friends maya. if i remember rightly you need to turn off the monitor or the input in the maya 44 config so that it just goes to vdj and not direct to output (think thats right wil double check when i see him at weekend)
googles you friend. hopefully this will help
http://uk.youtube.com/watch?v=LCvV1DCQWMs first few secs shows what im on about
geposted Tue 13 Jan 09 @ 3:42 am
here you go...
geposted Tue 13 Jan 09 @ 8:50 am
cheers for adding the vid, didnt know how to embed. (mental note learn how to do more cool tricks on forum!)
geposted Tue 13 Jan 09 @ 9:46 am
