Strange, my TCV signal is fading towards the end of the tracks / segment in the vinyl. At first it's 100% then slowly fading down to nothing towards the remaining 5 segments in the Timecoded Vinyl.
What to do! Please help.
geposted Wed 14 Jan 09 @ 4:52 am
Hi buddy;)
Are the tcv worn out? Are all the cables n grounding done properly? Check ur stylus too;)
geposted Wed 14 Jan 09 @ 2:35 pm
Hey SpinnaJ
All are properly connected to ground.
I replaced the old M44-7 (sensing it was the stylus problem) with the same brand and model (brand new) x2 but problem still exist. I never had this kind of problem with M44-7 before.
The running hours of one side is maybe up to 96hrs while the other side is untouch, using the untouch side doesn't solve the problem. All has a common problem with the two TT's.
I wonder why it only happen towards the end portion of the vinyl...
100% signal = up to 3/4 part of the timecoded vinyl while fading towards 0% is the remaining 1/4 part of the vinyl.
Any other suggestion is very much appreciated.
geposted Thu 15 Jan 09 @ 1:31 am
Mine did that, I did solve it but I dont know which one of these actions did it:
Changed earth cables for slightly higher guage
changed stylus completly to ortofons
changed rca leads to gold plated
shortened length of rca leads between soundcard and mixer.
dunno which one, but its all good now
geposted Thu 15 Jan 09 @ 5:14 am
Could it be something to do with the anti-skate setting on your deck, I believe that does something to the angle of the stylus as it moves towards the centre of the record.
geposted Thu 15 Jan 09 @ 9:14 pm
