i have installed virtualdj onto my mac and have it in the applications folder and also into the dock. but when i click on it in the dock it just 'jumps' up and then nothing.
Any ideas whats wrong
Cheers
Cheers
geposted Thu 15 Jan 09 @ 4:02 pm
Pls register ur serial n upgrade to the recent v5.2.1 mac;)
Regards;)
Regards;)
geposted Thu 15 Jan 09 @ 4:03 pm
Have just downloaded v5.2.1 and has come up with the instal file but when i double click on it the installer comes up in the dock but nothing else happens it just stays theres.
Any help please.
Any help please.
geposted Thu 15 Jan 09 @ 5:15 pm
Hi welcome to the mac community.
Could u delete the preferences file and try to reinstall. Also can u open the software via application not by the dock??
geposted Fri 16 Jan 09 @ 5:39 am
use app zapper to remove vdj and reinstall. After that repair you permissions, then set the VDJ folder to read and write.
geposted Fri 16 Jan 09 @ 8:39 am
i thanks for the help will try this later when get home to my mac.
Just one thing just want to check what OS should i be running so i can use Virtual DJ correctly.
Cheers
Cheers
geposted Fri 16 Jan 09 @ 9:23 am
Best use with leopard but tiger is fine;)
geposted Fri 16 Jan 09 @ 9:31 am
Ok kool thats good then, Just my mac hasnt got the specs to be able to run leopard well enough. :)
geposted Fri 16 Jan 09 @ 9:34 am
What mac are u using if i may ask n the specs?
Regards;)
Regards;)
geposted Fri 16 Jan 09 @ 9:38 am
Apple Powerbook 'Titanium'
PowerPC G4
800mhz
1GB Ram
Mac OS X 10.4.11
If that makes sense :)
PowerPC G4
800mhz
1GB Ram
Mac OS X 10.4.11
geposted Fri 16 Jan 09 @ 9:46 am
PowerPC G4
800mhz
1GB Ram
Mac OS X 10.4.11
PowerPC G4
800mhz
1GB Ram
Mac OS X 10.4.11
Hi chrispk,
This are the recommended system requirement on mac.
Mac OSX 10.4.7 or higher
Mac/Intel Core Duo 2.0 GHz or higher
1 GB RAM of higher
200 MB free on the hard-driver
Minimum system requirements on mac.
Mac OSX 10.4 or higher
G4 1.5 GHz or Intel Core Duo 1.6GHz
512MB RAM
But urs should be able to run vdj. Regards;)
geposted Fri 16 Jan 09 @ 9:50 am
His Powerbook only has 800 mhZ, no wonder it won't run.
geposted Sat 17 Jan 09 @ 9:23 am
