Topic: pitch and bpm
hi
i have a question
I bought a hercules rmx a couple of days ago and now i'm seeing that even when the pitch is at the center of the board
the pitch level doesn't match.
so for example: my pitch is at the center on the rmx and the song is 135 bpm and on the virtual dj screen when it's loaded there it is 134.9 bpm. it's always 0.1 that doens't match. and than there is another strange thing. when I push the button pitch reset and I want to pull the tempo down afterwards, it doesn't react then i have to speed up the tempo a little bit and then i can go slow it down.
ps. sorry for my bad english but i don't know much about dj stuff :-)
geposted Fri 16 Jan 09 @ 5:12 am
Hy Kavario,
with the 0,1 doesn't match it's nomal. I had it too, but not always. So it doesent matter to me!
Press if you want to regulate the 0,1, the button on the skin or do it by keyboard/shortcut.
I think your problem with the latency of the pitch pusher is also a normal problem.
Another idea, go to the download section and in plugins -> Tools & Drivers there is a new mapper.
Try this.
The other way I belive, is to buy the VDJ Pro. Inside the Pro there is a general mapper, called General Midi. With General Midi you can adjust all the available functions between VDJ and the rmx. Long Way.
I had the Numark Total Control there was it the same and now I use the vci100, but I never use the pitch pusher.
I have made four keyboard shortcuts for left deck (BPM UP/BPM Down) and right deck the same.
Very smooth!
Take a look into https://virtualdj.com/forums/31/Hardware_Technical_Support.html
Maybe there is a better help.
Good luck
Haui
