Are 7200rpm hard drives better for VDJ than 5400rpm hard drives?????
geposted Fri 16 Jan 09 @ 8:23 pm
yep...
geposted Sat 17 Jan 09 @ 7:08 am
Yes they are, I have both, and to be honest I can't tell the difference performance wise.
My old drive was a 5400rpm drive, my new drive is 7200rpm. The only way I can tell it's a faster drive is when I come to transfer files onto it. When I use it with VirtualDJ it's just performs the same as my old drive did.
geposted Sat 17 Jan 09 @ 7:14 am
Interesting, i would of though that since hhd goes straight into ram back and forth, i would of been best to have the fatest hard drive speed and the biggest cache you can get too.
geposted Mon 19 Jan 09 @ 12:08 pm
If you are doing loads of video then there's probably a difference, but for music it's zilch. I have used laptops to DJ with since 1999, and even the old 4600rpm drives handle music perfectly.
geposted Mon 19 Jan 09 @ 3:19 pm
You would only REALLY notice a VDJ performance difference when mixing video.
VDJ doesn't really read/write much to the harddrives when audio only mixing (loading the mp3, accessing the database), most of the grunt comes from CPU, not disks!
That being said if I was purchasing a new computer I'd demand 7200rpm or higher simply because they cost almost nothing extra.
But if you were thinking of upgrading 5400rpm's then I wouldn't bother, spend the money on a better CPU!
geposted Mon 19 Jan 09 @ 11:33 pm
Once your PC has booted and VDJ is safely loaded not much data will be written to and from memory and disk, if you have enough memory.
For a dedicated DJ PC with only VDJ loaded and no antivirus/firewall etc loaded, I'd recommend 1GB for an XP machine and 2-3GB for a Vista machine.
You may require more if you're video mixing.
Open task manager and go to the 'Performance' tab and check out your 'PF usage'. As long as this is 75% of your RAM or less then you'll be fine. If not consider upgrading your RAM.
geposted Mon 19 Jan 09 @ 11:44 pm
Sweet, well i got a Macbook Pro, with 4 gb of ram and 2.2 ghz Core 2 Duo. My machine is super stable, was just wondering that maybe a lower drive would of make bottleneck for the rest of the system. But yeah it makes sense, all is loaded up, and its not the occasional track loading that will ask alot of disk usage.
geposted Tue 20 Jan 09 @ 10:19 am
