Basically I just downloaded the titanium skin, but i dont like it.
But I cant find the config button?
Can anyone tell me where it is?
Cheers xx
Cheers xx
geposted Sat 17 Jan 09 @ 2:23 pm
Bottom left corner
geposted Sat 17 Jan 09 @ 2:25 pm
if you dont wanna use it, just delete if from your skin folder, and start vdj again
I have no idea where it is either lol ...
Cheers mate.
Its not called config, its called set.
Much thanks
xx
Much thanks
xx
geposted Sat 17 Jan 09 @ 2:27 pm
"SET" short for settings. You just get used to config, and them some smart a@# goes and changes it to set............I hate that;-)
geposted Sun 18 Jan 09 @ 2:38 am
well if they are going to the trouble to make the skin for people that have purchased the software they can call it what they want can't they...
geposted Sun 18 Jan 09 @ 3:56 am
