USB Drop outs as my friend called it... I never take Numark virtual vinyl out of my Studio but laterly when ive been taking it up a radio station im on and eventually take it out with me to clubs, were the following I cant really allow for any more... When i select a new track (pretty much eery time) i hear a annoying glitch in the sound also when I do over things in the software.. It even some times does it when im using just the Software and no timecodes. Any solution to the problem?
Dual core 1.5ghz
2gig of ram
Toshiba - vista
I did have a search on the forum could not find much to help me. Thanks Danny.
Dual core 1.5ghz
2gig of ram
Toshiba - vista
geposted Sun 18 Jan 09 @ 6:40 am
It could be a few things Danny, first of all though, go into your device manager and disable your Wifi adapter and maybe you internal modem, thats if you have done that already.
Any anti-virus or firewall and you system, disable that when you have VirtualDJ/Virtual Vinyl running or uninstall totally.
You could also look into your Performance settings. in the Performance tab, you could try these setting.
Set the slider to Fastest, put the latancy on Auto.
Uncheck Safe mode and Overclock (if they are checked)
Give all that a go.
geposted Sun 18 Jan 09 @ 6:51 am
