can I get a little video of the preferences do? including router settings.
I've tried several times but failed
thx
phil
thx
phil
geposted Mon 19 Jan 09 @ 7:33 am
Phil,
You need to be able to access your computer from outside of your home network. To do this, you need to open a port on your router. The settings in VDJ should be fine the way they are. Take a look at the documentation for your router, as well as the following link.
http://en.wikipedia.org/wiki/Port_forwarding
If you're not familiar with networking, I would advise against broadcasting. You are opening up your computer to the world, and you need to make sure you do it correctly. Another piece to the puzzle will be your public IP address. You can find this in your router's configuration interface. Note, that this will change on a semi-regular basis. ISPs use DHCP to allocate access. You'll need to know your current IP address every time you want to access your broadcast.
Be careful.
J
PS - You can always just create your mix and put it on rapidshare or something...
Be careful.
J
geposted Tue 20 Jan 09 @ 3:22 pm
:8000 is open and i know my ip, BUT IT DIDNT WORK =(
geposted Wed 21 Jan 09 @ 4:05 am
