I didn't find anything about this but it's probably a reposted question. Would a Numark CD Mixer 2 be able to plug into my laptop and externally control virtual dj?
geposted Mon 19 Jan 09 @ 9:37 pm
Technically speaking yes you could but you'd need VirtualVinyl with Timecoded CD's.
That being said looking at the specs I don't think you could use both decks on the CD Mix 2 to control both VDJ decks independently.
I reckon you could only use one deck of the CD mix 2 to control one or both deck of VDJ using timecoded CD's, because it only has one stereo output.
geposted Mon 19 Jan 09 @ 11:59 pm
if you want to route the two decks from vdj to the two inputs from the numark cd-mix 2 you need a asio soundcard and vdj pro or numark cue or numark virtual vinyl. there is no plug and play function to connect your mac/pc to this deck.
and there is no way to controll the internal functions of vdj. for this you need a midi controller.
geposted Tue 20 Jan 09 @ 6:16 am
