I just downloaded the virtual Dj v5.2 free trial and I can't seem to run it after I installed it. Something comes up that says "Invalid skin error". Any suggestions?
geposted Tue 20 Jan 09 @ 10:15 pm
Means one of your skins is faulty, or not made for your version
Inside VDJ skin folder, remove all skins, except the default one.
Then start VDJ again.
then it will work again :)
geposted Wed 21 Jan 09 @ 2:30 pm
There isn't even a VDJ skins folder??
geposted Sat 14 Feb 09 @ 1:55 pm
It is, you just have to look for it.
geposted Sat 14 Feb 09 @ 1:57 pm
