Am having issues loading the Xponent Contrler in VDJ. Every time i try to load it up in config/remote control, it just hangs there and make VDJ crashe. I know this much, if i use General Midi and assign some key's it works great, so i know that it reconize my xponent.
Anybody knows a fix or a work around ?
Thanks in advance.
Thanks in advance.
geposted Wed 21 Jan 09 @ 4:43 am
Nobody wana help out ?? :-(
geposted Wed 21 Jan 09 @ 10:46 am
Never seen that before.
Does it work fully under Torq and are you using the latest drivers?
geposted Wed 21 Jan 09 @ 1:52 pm
Yeah it works perfectly in TORQ, in Traktor also.
I have a Mac Pro, Dual Boot with Windows and OSX and a Macbook Pro with same setup.
On my Mac Pro, each time i try to load a controler, Xponent, Total Control in the Config/Remote Control Tab, it crashes my VDJ. But it works perfectly on my Macbook Pro.
It's the exact same setup, same windows instalation and all updated drivers with lastest VDJ installed. On Mac Pro i can use the General Midi insted and add my own midi inputs and it works perfectly, but if i try to use the integrated Midi Control it Hangs and Crashes my VDJ.
So i know my xponent works great.
Any solutions ?
BTW SBDJ check your PM's :-D
Thanks
Any solutions ?
Thanks
geposted Wed 21 Jan 09 @ 2:58 pm
Alright got it fix... I had to completly format my computer to get it working..
Kinda sucks if you ask me, but it works now so am a hppy nigga!
Cheers and Peace
Cheers and Peace
geposted Fri 23 Jan 09 @ 7:12 am
