Can anyone please clarify or give me a tip on this? I'm using a Numark Total Control with Cue, and there seems to be some erratic behaviour with the Gain settings when I load up different tracks to the decks. Sometimes, the new track will have the same setting as the previous track, but then sometimes it will be something completely different, like -3.8 or something. And sometimes, when I track comes in at say, 1.1, when I adjust the Gain knob, the value suddenly changes to something seemingly arbitrary, like -2.2. My files have all been run through MP3 Gain at 95db so theoretically they should have have the same Gain values. Is there sonmething I'm missing here, am I being stupid and ignoring some basic fundamentals when dealing with Gains. Please help if you can...
Peace,
Funkwit
Peace,
Funkwit
geposted Thu 22 Jan 09 @ 4:05 am
have you scanned your files ?
geposted Thu 22 Jan 09 @ 4:27 am
what do you have your gain config set to in the config window? did you update your firmware on your total control?
geposted Thu 22 Jan 09 @ 6:09 am
if it is the cue le edition that goes with te total control..you cant use the autogain function.You must upgrade to full version.
geposted Thu 22 Jan 09 @ 6:44 am
Thanks for the replies everyone.
Yes, I've scanned my files.
Yes, my firmware is up to date.
I think it's probably another LE limitation, so I've just upgraded to the full Pro version. Hopefully the autogain function will solve my problem...
Thanks again
Funkwit
Thanks again
Funkwit
geposted Thu 22 Jan 09 @ 7:32 am
Have you tried this, in the Option tab
Set the Auto Gain option to "Auto+Remember" if you haven't already.
geposted Thu 22 Jan 09 @ 8:53 am
