hi there,
couldnt find a solution to my issue - when i use any faders on my mixer there is a faint scratching noise in the background...
i used to have this issue before i started using my rmx midi controller so I know its my PC
here is my FULL spec - running xp not vista!
Technology type : Intel® Centrino® Duo processor technology featuring Intel® Core™2 Duo Processor T5450, Intel® PRO/Wireless 3945ABG network connection and Intel® GM965 Express chipset
clock speed : 1.66 GHz
front side bus : 667 MHz
2nd level cache : 2 MB
Operating system
Genuine Windows xp
System memory standard : 4GB
technology : DDR2 RAM (667 MHz)
Hard disk (Copy) capacity : 120 GB
certification : S.M.A.R.T.
DVD Super Multi drive (Double Layer) compatibility : CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-R(DL), DVD-RW, DVD+R, DVD+R(DL), DVD+RW, DVD-RAM
maximum speed : Read: 24x CD-ROM, 8x DVD-ROM/ Write: 24x CD-R, 4x CD-RW, 10x HS CD-RW, 16x US CD-RW, 8x DVD-R, 4x DVD-R (Double Layer), 6x DVD-RW, 8x DVD+R, 4x DVD+R (Double Layer), 8x DVD+RW, 5x DVD-RAM
type : Ultra light DVD Super Multi (Double Layer) drive
Display size : 13.3 "
type : Toshiba TruBrite® WXGA TFT High Brightness display
internal resolution : 1,280 x 800
Graphics adapter manufacturer : Intel®
type : Intel® GMA X3100
memory : up to 358 MB total available graphics memory with 2 GB system memory
memory type : shared
Internal video modes resolution : 1,280 x 800
maximum number of colours : 16.7 Million
Operating system
Genuine Windows xp
geposted Thu 22 Jan 09 @ 1:00 pm
Your windows specs arent really important here...
what mixer is it that you are using ?
geposted Thu 22 Jan 09 @ 1:07 pm
I am using my hercules RMX mixer...any skin I choose is the same...but this used to happen when I used purely the software to mix without the midi controller...please help!
geposted Fri 30 Jan 09 @ 2:33 pm
Hi.. Untick the safe mode in the performance tab in the config
geposted Sat 31 Jan 09 @ 3:53 am
