In the config menu, after going to options, there's a "MSN" opton and u can enable it, or disable it.
What exactly does this do? thanks.
geposted Fri 23 Jan 09 @ 8:08 am
Quote :
MSN - When activated, this option will allow your MSN Messenger to show the music you are playing. To take advantage of this feature, you need to make sure that the "what I am listening option is on in your MSN Messenger.
geposted Fri 23 Jan 09 @ 8:25 am
