Hi,
I'm a long-time Virtual DJ user, but liked the look of the VCI-300 (which only works with Serato Itch), so picked one up a couple of weeks back. The hardware's very nice and the scratching is the best out there (mainly, I think, down to the hi-res midi), but Itch leaves a lot to be desired - e.g. the beatmatching algorithm doesn't work anywhere near as well as Virtual DJ's, so needs constant manual adjustment.
As a result I've switched to an EKS Otus controller (http://eks.fi/product.php?p=products&id=34) to work with Virtual DJ.
I'm happier with this, but wish Virtual DJ supported hi-res midi, which would improve the scratching a lot if my Itch experience is anything to go by. Any idea when this will happen?
Basically I have two alternatives:
1. Stick with the Otus/Virtual DJ and wait for hi-res midi to be supported for responsive scratching
2. Switch to the VCI-300/Itch and wait for the beat matching algorithm to improve
Any suggestions which way to go?
Thanks!
Russell
Thanks!
Russell
geposted Fri 23 Jan 09 @ 9:16 am
yeah look at what you want to do currently. Imagine as if all technology will stop. what would you be happy with right this second?
geposted Fri 23 Jan 09 @ 2:24 pm
Vestax Vci300/Itch are working perfect - Itch soft is basic but with a good bpm engine - I'm waiting for native support , because I want to use it with Vdj .
BTW: Vci300 & Eks Otus are different kind of controllers , they aren't good for scratch ...if you want to scratch go for TCV or Numark Ns7 .
geposted Fri 23 Jan 09 @ 3:04 pm
i understand your purest ideals but this statement is not really warranted the vci-300 ect are good for scratching
this is scratching no matter how you look at it.
geposted Fri 23 Jan 09 @ 3:24 pm
