do the skins use more cpu than the default full video ??
by skins i do mean all of them ... seems unlikely to add something and use less ?
geposted Fri 23 Jan 09 @ 7:42 pm
There might be a little bit higher initial usage Chuck, but once the program/skin is loaded I imagine there to be no difference. After all the "picture" is static after loading.
geposted Fri 23 Jan 09 @ 7:51 pm
thanks Teary .... i've been using VALEMIX a bit lately which I like a lot , and it has a neat cpu meter with the usage displayed as a number % not a vague bar graph .....
i happened to notice over the course of the last week , which was like every week in that i was using VDJ at a minimum of 45 hours
maybe someday if I'm really using it a lot i could be a beta tester ......
geposted Fri 23 Jan 09 @ 8:01 pm
