i need help i have alot of effect but i cannot use them in vdj they do not show up when i go to the effects tab am i suposed to install them or something please help and thanks in advance.
geposted Sat 24 Jan 09 @ 12:54 pm
Hello,
In VirtualDJ's trial version, there are a few effects already installed.
Adding more effects, and downloading them is only possible when buying VirtualDJ.
geposted Sat 24 Jan 09 @ 1:27 pm
i have the same problem . they told me the effects that not work are old ones they need to be upgraded
geposted Mon 26 Jan 09 @ 9:28 am
bonjour j'aurai aimer savoir comment utiliser l'effect fader start j rien pigé merci
geposted Mon 26 Jan 09 @ 1:04 pm
Hello,
im not using the trial version i purchased it or well my friend purchased it im just trying to help him get the effects to work thats why i did not register nothing i was just trying to get some help i thought were better to go then the forums but do i need to install them or jst drag them to the effect plugin folder?
geposted Tue 27 Jan 09 @ 12:21 am
When your friend comes to VirtualDJ's website and downloads a plugin that comes as an executable file (extension is .exe), your friend must double-click on the downloaded file, and it is installed automatically.
geposted Tue 27 Jan 09 @ 4:35 am
