Topic: Urgent Help Needed??
hi everyone..i hav a party tonight and i m trying to figure out virtual dj to mix songs through my laptop using ..i got 2 headphone jacks on my laptop
1- for speakers
2- headphones
i can hear the songs simultaneously but i want to mix the songs using headphones without disturbing the audience through speakers..i am not able to figure it out..please explain it .
geposted Sun 25 Jan 09 @ 2:01 am
Your version of VDJ is most likely not supporting it. If you are using a cracked demo it wont work-
You need to buy VDJ Pro here:
https://virtualdj.com/buy/
VDJ pro supports two stereo outs, where one can be used for headphone, as well as a many other soundcard setups
you should be able to change your output settings, but only if you have Pro. UPGRADE. best decision i made.
If you want to be a DJ, you have to be prepared. Waiting until the last minute to get your equipment (software) in working order, is not being prepared. Even if you are doing the party for free, you should have been practicing on the software for weeks. That's lesson number one. Lesson number two; I hope you have a backup plan.
