right i have just started usein vdj,when i sync the beats they do not match up,so i use the pith bend to get the beats lined up,but the skins with pitch bend are crap,so i got the cdj 1000mk2 but there is no pitch bend. dose any one no how to add pitch bend buttons to this skin or is there a short cut for it,can some one help as i love this skin but can not mix with it thanks for your time
geposted Sun 25 Jan 09 @ 8:38 am
Hi,
Skins are only available to registered users of VirtualDJ.
You will get access to alot of other skins (including variations of CDJ1000) after buying VirtualDJ.
Click here to see all available skins
geposted Sun 25 Jan 09 @ 9:17 am
