I'm making a new skin for automixing purposes with a touchscreen friendly design.
Here is a screen of the first steps...
http://www.plaatjesupload.nl/bekijken/1247009.html
This is just the start but it gives an impression of how it will look be
In the skin i would only build in one channel and there comes a video window in.
The target is to build a skin for touchscreen use. that could be used by everyone with no experience such as barkeepers. In the skin they can put nummers or clips in the playlist with their fingers and VDJ does the rest.
geposted Sun 25 Jan 09 @ 2:56 pm
i like the idea in auto-mix mode where you get 2 waveforms of the current song, and the next song..
but you also get a cue marker where VDJ will auto-mix to the next track.
if you make the track waveform big enough, this marker can be easily moved with a finger (a la Touchscreen)
geposted Sun 25 Jan 09 @ 3:07 pm
The skin looks nice :)
As for now, it has a professional look!
geposted Sun 25 Jan 09 @ 3:55 pm
Do someone know how to change the songtime from 00:00.0 to 00:00 The .0 have to go off. I only need the HH:MM by the normal time it can be changed but by the songtime it doesn't work.
geposted Wed 28 Jan 09 @ 8:32 am
<text font="ARIALBOLD" size="12" color="#FF0000" align="left" weight="bold" format="%hour"/>
"%hour" is what you are looking for.
Or maybe you can make smaller the size of the thext and using as format="%fullhour"
Cheers!!
Cheers!!
geposted Wed 28 Jan 09 @ 9:40 am
This isn't possible for the songtime.
geposted Wed 28 Jan 09 @ 12:31 pm
