anyone know whats the best software to broadcast the videos from virtual dj? if i was wanting to broadcast the video mixing onto the internet. im looking for one that can snap to the video on virtual dj. apologies if this has been discussed already .i did a search and couldnt find anything
geposted Sun 25 Jan 09 @ 4:34 pm
Windows Media Encoder :D
geposted Sun 25 Jan 09 @ 4:54 pm
nice one so i can use this to pick up whats happening on the screen of my laptop and broadcast it live to a web page then ?thanx for your help :)
would this program work well with justin.tv? for broadcasting?
i can use other ones like smart cam etc but if media encoder works id rather use that. i can manage to get whateve i need on my desktop recorded as a file but im wondering if i can get it broadcasting live straight to that website?
geposted Sun 25 Jan 09 @ 6:14 pm
For justin.tv as well as blogtv, mogulus, and sites like that you should use ScreenCamera because you can set the frame-rate and easily select parts of the desktop and you can also have your webcam showing at the same time mixed into the desktop video. I use it and I recommend it.
You can find ScreenCamera here:
http://www.pcwinsoft.com/screencamera/
http://www.pcwinsoft.com/screencamera/download.asp
Best,
Alex
Best,
Alex
geposted Wed 25 Feb 09 @ 5:32 am
nice gadget/link
geposted Wed 25 Feb 09 @ 5:50 am
